Z-seam alignment randomness problem?
ViperZ
Posted · Z-seam alignment randomness problem?
I've set the Z-seam alignment to random, but it often prints from the same corner over several layers.
I would like to make sure that adjacent layers do not print from the same corner.
Thank you.
    I don't know why it happens, but it can happen, maybe it is a bug, I don't know.
    But I suggest do use the User specified setting and set the position to a place where it doesn't matter. I use this settings for most of my prints and get good results.
    If you want to report the behaviour (maybe a bug) about the random alignment, I would ask you to open a bug report on Guthub.
    https://github.com/Ultimaker/Cura/issues
    Thanks!
    Thank you.
    Random can give repeats.  It’s probably just because that’s the way random numbers work.
