The regular Ultimaker 3 firmware (5.2.12) does indeed not support these features. I'm not sure you how had these features before, but that was likely via the local network UI instead of the cloud?
Chris
Chris
It was the local network UI (i.e. using the local ip address in my browser OR drilling down via the cloud interface into the local UI) but, interestingly enough, I was able to manage via those LOCAL ip addresses when not connected in any way to the campus network.
It was spooky, and none of my IT guys could figure out why it worked, but it did in fact work.
jack
ALSO, to be clear, my student assistants were able to manage the print queue in the same way, so the functionality was consistent.
Edited by ksjack
Dim3nsioneer 532
Do you use Ultimaker Essentials Early Access? Then please get in contact with your reseller and ask him for a Digital Factory compatible firmware for your Ultimaker 3.
