tinkergnome 929
I think there is something wrong with the mesh structure of this model. It looks like there are extra (double?) walls around the holes or something similar.
It's probably not a single solid body (like it is supposed to be). If the model has errors the results are simply unpredictable.
As a first step i would take a look at the "x-ray-view" in Cura and check for any unwanted geometry or red marked areas.
DeanS 0
Well I guess I'll answer my own question. After continued playing around and no better results, I tried subtracting .01 mm from the thickness of the base. There is still the same amount of layers but the infill doesn't cross the hole anymore with the same settings. It must have something to do with a fraction of a layer height making cura do something wrong during slicing.
Here are the two models with the second one with .01mm removed.
Same number of total layers.
