Posted · Bug: Mixed Y/Z scaling after rotation
Affects Cura 4.7.1 under W64.
Method A to reproduce:
- Reset all model transformations
- Rotate a part 90° around X
- Disable uniform scaling
- Change Y % to 105%
 - (Wrong) Z also change to 105% and further increase by 105% each time it receive focus
Method B to reproduce:
- Double Y mm value
- (Wrong) Z % increases to 200% (it should be Y % at 200%)
    I think it's a glitch too.  Your problem with the Z scaling is because you rotated around the X.  If you rotate around the Y, and then make your transformations, then the problem moves to the X axis.  Kind of bizarre to say the least.
    The workaround is to make the transformations BEFORE rotating the model.  I haven't had any trouble doing it that way.
    I took the liberty of adding this to Github as a bug report.
    What I'm seeing is that after you rotate the model about the X and then scale the model to 105% about the Y, the Z does indeed also say 105% - but the model doesn't reflect that (I used 150% to make changes easier to see).  De-selecting and then re-selecting the model leaves Z scale at 105 and the Y scale is at 100, but the model still looks correct.
    When you rotate the model first, and then non-uniformly scale the model then depending on which axis you rotated about, a different axis will appear to be affected as well.  Rotating about the Z and scaling in the Y will result in the X seeming to be effected.  The model still looks correct to this point.  Trying to straighten out the numbers in the dialog box results in a mess and at that point the model transformation cannot be reset.  The plate has to be cleared and the model re-loaded.
    Rotating as the last step in transformations appears to solve the problem.  When de-selecting the Uniform Scaling option, if a pop-up appeared and explained that rotation should be done last then that would have been helpful.
