Firstly note that if your bowden comes out, you don't have to buy a new one - just cut 2 to 4mm off the end and now you have fresh bowden in the collet.
Terms: Collet - the white part (collet is from "Collar"). A collet is a round clamping thing that clamps some kind of cylinder inside the collet.
Clip - the horseshoe shaped part - usually blue or red. Or black or white.
If your bowden is slipping it's possible that the Bowden is the wrong diameter. Not a problem if you got it from an Ultimaker seller and not a 3rd party.
More likely you need to replace the Collet. It has 4 blades inside - like razor blades almost. They can get damaged in many ways.
gr5 2,072
You mean UM2+. I'll fix your description.
