If that doesn't help - what comes on? Do any lights come on? If not do you have a meter? Can you check the voltage coming from the power brick?
Tried all these suggestion, nothing comes on at all.
i dont think this is the same situation.
but when i plugged in my ultimaker2 with usb. i started cura and clicked update firmware... of course my cura was still set for ultimaker 1 and uploaded the firmware for the um1 to my um2... that really shut down the whole printer... dead as a doodoo.
so i changed my cura to ultimaker2 and then reconnected usb cable and reinstalled the correct um2 firmware... then restarted and worked perfect !
maybe worth checking which firmware you loaded ?
Ian :-)
No lights? No fans? Nothing? Not even a blue light on the power brick? It's starting to sound like your power brick is broken. Or maybe the electrical outlet you plugged it into.
Hi gr5,
Only the blue light on the brick is on, the rest is completely dead. I tried everything you can think of but still no life in my printer.
If it were me I would take the 2 screws off the bottom cover and remove it. Then trace the power cord and power switch and make sure when the power switch is on the power gets past the switch. I would test this using a meter. Then I would trace this signal to the main voltage regulator - a large part with 3 large pins. I would check to make sure the part generates 12V. But truly the problem is probably before this part because I think the 19V goes directly to the rear fan and so if the rear fan doesn't spin then something VERY SIMPLE is broken. I think. Possibly the switch. More likely a cable or connector right there where the power comes in.
gr5 2,333
Try disconnecting USB cable if connected. Then disconnect power cable from home power. Leave disconnected for a very long time - until the blue lights goes off. 20 minutes for me! If you turn on the UM2 while the "brick" is unplugged you should be able to get the light to go off in one second instead of 20 minutes.
Then turn off UM2, plug in the power brick and turn it back on.
Some power bricks have circuitry that won't reset until you power cycle them.
