1 hour ago, GregValiant said:Z steps/mm
Z Axis binding
The screws holding the Z axis rod into the coupler and onto the stepper motor shaft are loose (popular problem).
I was hoping you were right but I got the allen wrench and checked and the couplers are both tight. I can run the z axis up and down without any binding. And the print looks fine other than being thinner than it should be. What do you mean ny "Z steps/mm"?
GregValiant 145
Z steps/mm
Z Axis binding
DivingDuck 58
What do the gcode say as last Z height?
