issue with Cura 4.7 and wndows 10
t3dm
Posted · issue with Cura 4.7 and wndows 10
Hello all, it seems i have a weird issue hen starting Cura. it does all the checks and opens the windows, but it stays white and it hangs.
tried to unistall, remove the folder, rebooted and reinstalled. it started and arrived at the printer configuration. it hanged and i had to terminate it again from that point on nothing again.
i updated my drivers, tried to run it in compatibility mode but nothing same results.
checked the event viewer and i get this data:
Problem Event Name:    AppHangB1
Application Name:    Cura.exe
Application Version:    0.0.0.0
Application Timestamp:    5f2c0247
Hang Signature:    3d1a
Hang Type:    134217728
OS Version:    10.0.18363.2.0.0.768.101
Locale ID:    2057
Additional Hang Signature 1:    3d1a3955c964841e0a6db14fc7a89f6f
Additional Hang Signature 2:    b6b6
Additional Hang Signature 3:    b6b624192fb64ce979c312febff456bc
Additional Hang Signature 4:    3d1a
Additional Hang Signature 5:    3d1a3955c964841e0a6db14fc7a89f6f
Additional Hang Signature 6:    b6b6
Additional Hang Signature 7:    b6b624192fb64ce979c312febff456bc
Extra information about the problem
Bucket ID:    ddc35cb8901d3e440747476a0af39ff7 (1677387906994642935)
google does not return any info about it. any idea?
    so it looks like it has something to with the cura wndows opening on my second monitor. if i change the windows parameters in the cfg file then t opens correctly.
    is there a way too put a command in the cfg file that override the starting windows position?
        • 6 replies
