I think I don't understand your question, can you explain it a little bit more please?
I would say the line width is wider on the blue one. So you can try to slightly increase the line width, but not too much, it should basically match your nozzle size, but you can try to set a higher value. i.e for a 0.4 nozzle a line width of 0.5
And it seems the bed leveling is much better with the blue one. The other object looks like that the distance nozzle/bad is a bit too big, so you can also level your bed again, that the first layer gets more squished into the bed which results in bigger line widths.
But generally the amount of lines matches the thickness of the model and is a result of the line width together with the nozzle size. So for example, nozzle 0.4 = line width 0.4. The wall on the model has a thickness of 1.2mm. Then you print 3 lines a 0.4 = 1.2mm
In the above example it is also possible that the blue model was printed with a bigger nozzle, maybe 0.6.
1
Thanks very much for your help 🙂 very clear, i will try edit the line width.
im not sure if my bed level causing the line problem because it was from the raft that i added. But i will see if changing the line width will make difference.
You are welcome 🙂
Try different settings and values in Cura and check the preview. So you can quickly try different settings without printing every version.
1
Thank you 😀 thats a good idea, I like my setting so far, my prints are really nice, its just this part I want to improve, hopefully get it right. I will test it out.
But be careful, to tune it to get only 4 lines. There is reason why the other model has 6 lines and it is normally ok. The methods I mentioned above are settings when you really need or want the 4 lines and if you set too extreme values you can get other visual problems.
But other question, have you printed the blue one yourself? I mean do you know the nozzle size and other settings of this model?
I was playing around with the settings and now i dont have 6 lines, I have about 12 lines. I dont even know how this happened. For the blue cutter, I brought it from someone. I guess she had a bigger nozzle size. I am not sure because she has a shop and she dont give out any info about her process. Her cutter is very high quality. I am not sure if my ender 3 can produce the same quality.
Smithy 1,141
When you increase the number of wall count to a high number (i.e. 99) then only walls are printed and it should look like the blue one.
huggibunni 0
Thanks for your help, I want to know how I can have less lines, I want 3 but i get about 8 lines
