It does not have Marlin, so it would have to be done from the printer screen, could you tell me how to do it? thanks
41 minutes ago, Criscuen said:have to be done from the printer screen, could you tell me how to do it?
In case you want to stick with "UltiGCode":
https://support.ultimaker.com/hc/en-us/articles/360013127919
Thank you very much for everything, I tell you when I open the CURA I don't get the Marlin thing, it could be because I have not added the network printer, but rather, I added the printer. Although it is true that I update the firmware of the printer from CURA.
Hmm? network is not available for the UM2 so this is not the reason. Have you added the printer as an UM2+ Extended?
Can you post a screenshot of your machine settings page like mine above?
Which Cura version do you use?
Looks good and now change it to Marlin instead of Ultimaker 2, just click on the drop down.
OK thank you very much
Smithy 1,146
Check in Cura in the printer settings if you have Marlin as GCode flavor. This is important to set the temperature in Cura, otherwise you have to configure the material in the printer itself.
