It gives better print results, and the defaults are just right. Also, printing PLA at 250C is a bit overkill. 230C is more then enough. PLA is even printable at 190C (but slower)
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Daid 304
Feels like a wrong setting in Skeinforge, I've seen it do the same. Check if the Temperature plugin is enabled, and if it is, disable it.
But your printer is working. That's good. Maybe you can upgrade to SkeinPyPy:
https://github.com/daid/SkeinPyPy/downloads
