What CAD did you make this in? I have a file with different advice for different CAD packages.
GregValiant 1,489
A couple of other things to consider...
1) In the Ender slice - do you have coasting enabled? That will create what look to be gaps in the preview because there isn't any extruding being done in those "coast" areas.
2) Is the Top/Bottom Pattern set to Concentric? (Because it looks like "Lines" in the slice for the Prusa.)
gr5 2,330
90% sure it's the model, not the printer. Tiny changes in printer settings (particularly layer height) can hide problems with a model. So try this:
In the upper right corner of Cura click "marketplace" and make sure you are on the "plugins" tab and install "Mesh Tools". Then restart Cura. Now right click on your model, choose "mesh tools" and first choose
"check mesh", then "fix model normals" and "fix simple holes" to see if that helps. Cura doesn't fix most issues so...
netfabb free repair service is here (you have to create a free account first):
https://service.netfabb.com/login.php
Here's another service - drag and drop mesh repair service:
https://3d-print.jomatik.de/en/index.php
There's also an x-ray mode in cura that shows certain problem spots in red but "mesh tools" is better at finding problems.
