Ultimaker Community of 3D Printing Experts
Ultimaker Cura 4.8 BETA is available
Posted · Ultimaker Cura 4.8 BETA is available
27 minutes ago, Johanmeij said:
Can you please give a step by step installation proces for on my Macbook pro, under MacOS Big Sur
Big Sur is still beta, so it is possible that Cura doesn't work yet with Big Sur.
    A problem has been identified with the 4.8 beta on Big Sur. It will be fixed with the final release of Cura 4.8.0, which will likely be released next week. If you really want to run the beta on Big Sur, there are steps but they are somewhat involved.
    Will the problem fixed with Cura (still in 4.8), Win 10 and the network disks , which obviously manifests itself in many cases and the only solution for now is to disconnect the network ... which is not very convenient?
    On 10/23/2020 at 8:21 PM, Longtoke said:
    From what  I understand of this issue, it's only manifesting on 8-bit boards, predominantly on ( but not limited to ) Creality brand printers like the original Ender-3.
    Can confirm this does not fix the issue at least on my 8bit Formbot TREX 3. Circular/curved surface finish on the same printer is still better in S3D with similar print settings. Will continue investigating issue a report back if I make progress.
