Dim3nsioneer 557
I can confirm that with the ovality of the filament. I think every filament has some? Actually, I get a larger diameter when measuring in radial direction compared to axial direction. I usually take the axial measurements as I think the bending around the reel might make the measurement quite arbitrary.
Thanks for the hint with KISSlicer; as soon as I have set it up for the Ultimaker, I'll give it a try.
What about the temperatures? Higher, lower or the same as for pure PLA?
IRobertI 513
I don't get the knots on my prints (changing to KISSlicer got rid of them for me, but I haven't tested the very latest cura so that may not be an issue anymore) but I do get the visible layers. Have you tried measuring the diameter of the filament in more than one direction? My filament seems to be slightly oval and I'm thinking that may have something to do with it.
