Hi @SandervG,
Thanks for your reply,
I am printing the discs vertically intentionally to check how the layers might have an effect on the air permeability of a print.
I have tried printing several discs at once in several locations, with varying distance and angle.
I can try changing the bed temperature but it seems to me to be an error occurring at a specific z-height. The print seems to continue fine afterwards (see my second image, the first transparent PETG disc has a bad quality part at a certain height, but after that the print is fine)
SandervG 1,519
Hi @AHG, thank you for your message.
Does it need to be printed vertically, or could they also be placed flat on the build plate? That would make things a lot easier! In its current shape, on the bottom of the disc you are dealing with an overhang and heat/cooling issues. The heat that is radiating from the build plate is keeping the filament from solidifying, and so are the layers that are printed on top of it with a hot nozzle before the previous layer has had a time to cool down. Have you tried printing a few discs at the same time with some decent space in between so the head travels around a little bit and they have time to cool? I would also try to print them with the bed at a lower temperature, or perhaps even turned off entirely (but then you probably need to use a line of blue tape to ensure the adhesion). But again, printing them flat would be much, much easier.
