12 minutes ago, Smithy said:Hi
first of all, please make real screenshots, the photos of the bottom right corner just shows the summary how long your print will take, we cannot see the model or any other things you are talking about.
Slicing issues are 90% defects in the model itself. So I guess your STL itself has some error and therefore you get strange results when you slice the object.
Which software do you use to design the objects?
Can you upload your STL or even better the whole Cura project?
I'm using cura to slice.... the project is pending
Smithy 1,141
Hi
