And check if your network connection (ethernet) is really working, because normally there is no need to update via USB. But if a network connection is not possible, then download the FW on the USB stick and the process should be same.
Firmware update is done only from the printer, no Cura involved here. So on the printer in the settings menu - maintenance - update firmware
1
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Smithy 1,141
https://support.ultimaker.com/hc/en-us/articles/360011545559-Update-the-Ultimaker-S5-firmware
