How do I set Fill Density in CuraEngine
dougconran
Posted · How do I set Fill Density in CuraEngine
I'm using CuraEngine v3.1.0 on Ubuntu 18.04 to slice an stl file and using the ultimaker.def.json definitions file.  That file suggests that there is an infill setting called 'infill_sparse_density' with a default value of 20%.  When I first ran CuraEngine it generated a huge number of settings which I captured and then modified and used for subsequent slicing.  However, whatever 'infill_sparse_density' value I use the end result is always sliced with 50% infill.
How can I change the infill density?
Any suggestions would be gratefully received - thanks.
    As a general rule, only settings that don't have children in fdmprinter.def.json are actually used by CuraEngine. All the other settings are used in formulas to feed into those "final"/leaf settings. For example the infill_line_distance gets calculated from the infill_sparse_density and the infill_pattern by Cura (from a python expression) and fed to CuraEngine
    "value": "0 if infill_sparse_density == 0 else (infill_line_width * 100) / infill_sparse_density * (2 if infill_pattern == 'grid' else (3 if infill_pattern == 'triangles' or infill_pattern == 'trihexagon' or infill_pattern == 'cubic' or infill_pattern == 'cubicsubdiv' else (2 if infill_pattern == 'tetrahedral' or infill_pattern == 'quarter_cubic' else (1 if infill_pattern == 'cross' or infill_pattern == 'cross_3d' else 1))))",
    And the unreadable mess above translates to:
        return 0
    else
        if infill_pattern == 'grid':
            factor = 2
        elif infill_pattern in ['triangles', 'trihexagon', 'cubic', 'cubicsubdiv']:
            factor = 3
        elif infill_pattern in ['tetrahedral', 'quarter_cubic']:
            factor = 2
        elif infill_pattern in ['cross', 'cross_3d']:
            factor = 1
        else:
            factor = 1
        return (infill_line_width * 100) / infill_sparse_density * factor
      • Introducing Universal Cura Projects in the UltiMaker Cura 5.7 beta
        • 10 replies
        This update is for...
        All UltiMaker S series
        New features
