Yeah OK, but i looked into the g code using repetier and i noticed that after the pause command, it returns to the same position using a g1 and g92 code, or will the smoothie board override that probably?
GregValiant 193
As Smithy says, a homing move is not good during a print. I've been burned by that one as the tolerance of the switches is not good and there will likely be a layer shift of up to .5mm.
The G1 codes are doing a retraction, doing a prime, and moving the head back to the re-start position. Then the G92 E? resets the extruder so it is in sync to continue the print. The M82 sets the extruder back to absolute extrusion mode.
"...It broke the belts". If you have different users (students?) accessing this and they are always using the same printer then maybe the best thing is to modify the PauseAtHeight.Py file and insure that the "Park" location is within the Min and Max you would set in the plugin.
In both the "head_park_x" and "head_park_y" sections of the .Py file something like this might work.
"minimum_value": "-250",
"minimum_value_warning": "-250",
"maximum_value": "250",
"maximum_value_warning": "250",
You'd want real advice from a Python coder (which I am not). They should be able to advise on making an alteration so the dialog would not accept "garbage" input for that specific printer. It might even be preferable to have a location hard coded in so the user couldn't change it at all. You could save the Py file as "TevoPause.Py" and only use it for that particular printer.
Ok, ive had a look at it lately, and im now trying to get the print to pause through a g code pause in the file (like what pause at height is doing). Although im using prusa slicer which lets me insert any gcode i want before a new layer starts, but i've tried to do all the pause commands i know (M25, M600 and M226), but none of them have worked, do you guys know any other pause commands??
Btw, i thought the printer used repetier firmware but apparently tevo says it uses rep rap, but it has a smoothie board, im confused
GregValiant 193
1 hour ago, Slavsquatter3000 said:...im confused
Welcome to the world of 3D printing.
You can try M0 or M1 either of which will likely need a button click to continue. M999 might work to continue (but might cause the position to be lost).
Prior to version 3.01 RepRap used M601 (then changed to M226) with M602 as resume.
Here are a couple of links (although it sounds like you're already been to both).
https://reprap.org/wiki/G-code
http://smoothieware.org/stopping-smoothie
Edited by GregValiant
Ok, i'll try these codes, i've also updated the firmware because apparently the firmware on my printer was 7-8 years old.
And I ive now found out that it does use smoothie gcode flavor. Thanks for the help
Smithy 791
A real homing is not good, because you will then never be on the exact position again when you continue your print. The home switch has too much tolerance. So moving away as you like is the better solution.
