No, this is not a concern. Is that it is technically impossible to adjust ... So printing!
To libere the head, I manually lower the glass on the setting. The setting is as impossible!
Ultimately, if there existed a way to move the head a little, a one hand so to clear and settle the bed, it would pose no more problems.
IRobertI 520
I'm not sure if this has been fixed in firmware yet as I haven't updated in a while, you can try updating the firmware first and see if that stops this from happening.
If it doesn't you can swing the clip out and bend it down a bit with a pair of pliers to keep it from hitting the fan shroud (I did this on my machine). Or you can try to swing it out a bit until it clears the head but still keeps the glass in place. I noticed that if you swing the clip out completely the glass plate raises up slightly and screws up your bed leveling that way instead.
