I am trying to get the exact same outcome as the original poster (no bottom layers/0% infill/Bridged top layers). I have the latest version of Cura 4.12.0.
I am using the settings described by gr5 above. No spriralize and bottom layers/thickness set to 0. However Cura still adds the bottom layers! what gives??
gr5 2,094
NEVER PRINT something without checking the PREIVEW mode first and sliding the slider to see what will happen on all the layers. Never. That would have saved you a lot of time and will help you realize within seconds what each option in Cura does.
So I recommend you don't use "spiralize" as that has a built in "water tight" feature for vases and cups and I don't think you can disable that.
Then make sure "bottom thickness" and "bottom layers" is set to zero and you will get no bottom. Also disable infill as it sounds like you want your part to be hollow (no infill).
