3 hours ago, ahoeben said:Do you use multiple displays? If so, try disabling all but one of them temporarily. If Cura starts succesfully with a single monitor, go to the General preferences and uncheck the "Restore window position on start". Then you can re-enable the other screens, and Cura should always open on your primary screen.
I'm running 4 monitors, this did the trick! I unplugged all but 1 monitor and Cura opened normally. I was then able to access the menus and do as you stated. It seems to be working fine now. Thank you very much!!
1
ahoeben 1,107
Edited by ahoebenLink to post
nallath 844
Also; do you have a network drive on the machine?
