I assumed that I needed a prime tower when switching between printcores. I am using a UM3E printer.
the prime tower is not necessarily needed, but definitely improves the quality of dual nozzle prints.
making the tower wider might help, but the better way would be to activate the dedicaded prime tower brim (independend from "global" brim setting, especially designed to prevent prime tower fails).
Regards
The prime tower still fell. My print messed up close to the end. Is it possible in cura to start the print at a specific height with all the same settings, except for deactivating the prime tower? I carefully figured out my z height.
Framar 22
Do you really need a prime tower? With the S5 prints are better without it.
