GregValiant 1,250
@greens83 I downloaded that model. Cura shows errors and the hollow shape means there is a surface on the inside that faces air, and a surface on the outside that faces air. Those sorts of models aren't suited to Spiralize.
Your Gcode file shows the XY shuffle that is creating the seam.
After repairing the model in MS 3D Builder I get a true spiralize toolpath. Here is a preview of the repaired model in Cura. You see that it has only an outside face and is solid top-to-bottom.
This is in Cura X-Ray view. Your model is on the right and the repaired model is on the left. The red areas indicate model errors.
Open the attached gcode file in Cura. When I first slice it the preview appears to show a z-seam. Previewing the gcode in either AutoCad or in Cura shows that those shuffle moves aren't actually there.
Edited by GregValiant
Top Posters In This Topic
19
12
9
5
Popular Days
Nov 28
13
Dec 3
12
Apr 1
8
Nov 27
7
msageryd 19 posts
greens83 12 posts
GregValiant 9 posts
Smithy 5 posts
Popular Days
Nov 28 2020
Dec 3 2020
Apr 1 2022
Nov 27 2020
Popular Posts
GregValiant
I write a little code and I came up with a front end program for my printer. Part of the development was to make sure it was compatible with different gcode flavors and different slicers. I have a L
DivingDuck
That's the place I used to look at https://github.com/smartavionics/Cura/releases
Torgeir
Hmm, There is some issues with Cura when viewing the file in "slicing mode", I just come to think about this issue. just forgot this one, -open Cura 4.8, then load the actual gcode fi
Posted Images
greens83 5
