1 hour ago, gr5 said:That's almost surely a problem with the model. Did you try printing it? It might work okay - the lines might be close enough to bond. Look at it in layer view and lower the slider until you can see that slice/opening.
You can play with the cura "mesh repair" features or you can try sending it through a free repair service. But I suspect that tiny air gap is really there in the model and so the repair services might not fix anything:
netfabb free repair service is here (you have to create a free account first):
https://service.netfabb.com/login.php
Here's another service - drag and drop mesh repair service:
https://3d-print.jomatik.de/en/index.php
Thanks for your help, I tried to print it and had the issue.
I used netfabb repair service and seem to be good on Cura ! I will try to print it soon. Thanks !
1
gr5 1,506
