1 minute ago, Smithy said:Have you already successful printed something on your printer?
Do you have a presliced gcode file on the sd card which came with the printer? So you could try this file, just to see if it Cura and your settings or if you have a failure in your printer.
Thanks for your response. That was my first print attempt. But, there was a dog gcode file on the sd card that came with the printer and I got the same result, printing in one dimension. I'm assuming it's the printer, but I'm still confused as to why the Cura preview would also show the cube being printed "flat," e.g., printing only the Z side of the cube.
Smithy 757
