Posted · Cura 4.8,4.6, won't run on windows 8.1
Hey All,
I'm trying to get  cura up and running and can't get it to open all the way. I'm running windows 8.1 64 bit. I install the program and go to open in. I get the black status box and it goes all the way to loading interface and then the box goes away to finally open cura and I get the error cura.exe has stopped working. I also have tried running in compatibility mode for windows 7 with no luck. I"ve uninstalled and tried a few previous versions and they all give the same error. I really don't know what to try next.  I'm not sure if its related but I also tried to run prusa slicer and slic3r and get problems running those as well.  Currently I'm using simplify3d as but I would like to try some of the features Cura has.
