Posted
· Replacement for terminal block for bed heater
Big bed= high current, Hence it burning out. It probably pulls 10 amps when running. Might not have been tight enough, or worked loose from thermal cycling. It’s common to periodically shut down and relighten all connectors on industrial machinery plants
you can use any connector that works at the local electrical store, or just solder on directly. Just make sure you have good contact, a large well soldered joint will be perfect
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Jasonjason 6
