Hello Smithy, forgotten to mention but this is also enabled.
19 minutes ago, Smithy said:Sorry then I am out of more ideas, it seems you have already tried a lot.
Anyone else an idea how I can update the firmware with a custom fw?
You need an USB connection, so we should look into it, why it is not working. Strange is that you already tried different PCs and different cables.
@tinkergnome Do you have more ideas?
Yeah, even under windows I don't see in the devices the port when connecting the usb.
When I switch off the printer I see a "unrecognized device" and switching on then it disappears.
Very strange....
I would understand if it is only not working with the Mac (depending what you are using) because I had problems connection another printer with my Macbook because the USB-C adapter was not working. Another Macbook with normal USB was ok.
Maybe the USB port of the printer isn't well connected to the printer board? Or the the port is dirty?
Have also a Mac mini with normal USB ports, because MacBook Pro has only usb-c ports and will try later on with the mini. Will come back to topic if (not)successfully.
tinkergnome 926
On 12/6/2020 at 5:13 PM, jphermans said:Yeah, even under windows I don't see in the devices the port when connecting the usb.
The arduino drivers are responsible to create the (virtual) COM port. If this does not work, there's no point to proceed with different Cura versions or any other software.
Are you absolute certain that there's a genuine Ultimaker board in this printer? (most "clones" need different drivers)
The Arduino forum advocates against USB 3 ports and cables, that's perhaps worth a try? The USB-cable that came with the printer would be my first choice.
https://forum.arduino.cc/index.php?topic=521669.msg3557386#msg3557386
This is a original Ultimaker and no clone. Will read the link and let you know if I come any further.
Thanks.
Smithy 1,141
Please check if the USB Printing plugin in enabled in your Cura installation:
