Thanks mate, yes, I have used the grease on the x y rods, I assumed that's what it was for? I can wipe it off.
I'll check the screws, and see if the room temp helps.
Travel speed is still 150mm / s but I reduced the acceleration from 5000 to 2500
Thanks again.
x is left to right, y is front to back. Z is up and down.
When talking about pulleys slipping, we're referring to the toothed wheels that the belts wrap around on the rods. The pulleys are held onto the rods via a single grub screw. If that has worked loose, then the pulleys can slip on the rods instead of turning (or being turned) by them. In particular, if the short belt pulleys slip, then when the motor turns in one direction, the head may not always move as it should. This can cause the print to be seen to jump as in your pictures.
However, another cause may be skipped motor steps, where the electronics has asked motors to move but they did not. This can happen due to over-heating of the stepper drivers, too little current from the drivers to the motors for the speed or acceleration requested, or too much friction in the drive system.
So in your case, if not a loose pulley, it might be due to the temperature. Cooler ambient temps might help. Alternatively, did you alter your travel speed or acceleration settings? Slower travel speed might help (150mm/s, if you've gone any higher).
You mentioned greasing the rods? You didn't put the green grease on the x-y rods did you? That might have increased friction a bit, as it can trap dirt. It's best to use light oil like sewing machine oil for the x-y rods. Only use green grease for the z-screw.
illuminarti 18
