No I'm not. I'm using MKS WIFI to connect the printer.
Ok was just an idea.
And the MKS Wifi Plugin is also up to date?
I hope it is. v1.1.2
I am pretty sure the problem comes from the plugin, so maybe contact the developer of the plugin. There is often the need to adopt the plugin a little bit with newer versions of Cura.
Another idea is to check the cura.log file, maybe that gives more information.
Smithy 757
Do you use Octoprint and the Octoprint plugin with Cura?
If yes, are you on the latest plugin version?
