tinkergnome 927
On 12/8/2020 at 7:17 PM, r_moeller said:Just while writing I have checked with a built in profile which has Brim as standard Build Plate Adhesion Type and found that the area is small with Brim but gets huge by just switching to Skirt. That don't make much sense to me.
That's how i understand it:
"Prime Tower Brim" is a separate setting (try the search function).
It will be disabled (by default), if the adhesion type is already set to "Brim". That means: for the default profiles it is only enabled if the adhesion type is different from "Brim". So - simply disable "prime tower brim" explicitly if you don't need it.
r_moeller 6
Sorry, wrong screenshot, for Brim the scrrenshot is here
