Nice and elegant solution to use that more powerful adapter.
Just a note: each pin on the connector is rated up to 10A each. You are not allowed to double this capacity by operating in parallel. Safety regulations say that you also have to be within maximum ratings when 1 or more pins break down.
So, you are not allowed to combine the two pins in parallel as 1 x 20A
What you can do is 2 x 10A. That is, on your controller board you design the electronics in such a way that the bed is powered from 1 connector pin and the other circuits from the second pin.
Torgeir 148
Hi @Savak001,
you should use this power supply, as I do on my UM2+ext.
This deliver 295 W and work well.
https://www.pchub.com/dell-common-item-dell-ac-adapter-20v-above-24v-123a-4p-p14v-c14-p160274
This is Dell N112H 24VDC 12.3 Amp version and have the right type of connector for an UM2
Thanks
Torgeir
