Changing 1.75 to 2.85 in Cura while still using 1.75 filament is a stupid idea! One thing for sure, prints will fail, and you have a chance of damaging your printer
What brand of bowdentube are you using, I know Capricorn has 1.90 and 2.00mm inner diameter bowdentube, in both cases 1.8mm should be no problem...
Has Mari said, I suggest you replace the tubes and instead of chaging the filament diameter in cura you can adjust the flow percentage instead; this will give you more control and a more accurate print.
1
Mari 38
Framar 39
