What you see in Cura is just a warning, but if you really want to slice it with 0.02 it should still be possible.
To be honest I don't know it in that case.
It appears when you select a combination which is not supported or not recommended. Maybe that is also the case here, because 0.02 is really very unusual. When you enter 0.06 the warning is gone.
While you should be able to print at that layer height, unless you have a very specific reason to do so, it's mostly a waste of time IMHO. You can actually get worse print quality at such thin layers because any tiny variation in the filament or anything else along the extrusion chain can show up. Personally I never go below 50micron and even printing at that layer height is exceedingly rare for me.
1
Smithy 1,141
Hi
Yes, according to the specs it is be possible:
0.25 mm nozzle: 150 - 60 micron
0.4 mm nozzle: 200 - 20 micron
0.6 mm nozzle: 300 - 20 micron
0.8 mm nozzle: 600 - 20 micron
