You shouldn't need to use Digital Factory. I have 6.1 and I can still use my ethernet connection. I believe it is only with the firewall on do you need to use Digital Factory.
1 hour ago, yzorg said:
What a bummer: With 6.0 you can only use the Digital Factory, so you have to send your print jobs through the cloud. A direct connection is not possible anymore.
i might have to roll back then. this is a no-go for me.
This is simply not true. Only if you enable the new firewall feature in the printer settings. But it is disabled by default. Ultimaker would never introduce such a large breaking change to user workflows.
1
- 3 weeks later...
Hmm, that is not the case, you can still use local network (directly print from Cura to your printer) with 6.1.1
I sure hope you have discovered this by now 🙂
Nope, only with the firewall on. Firewall off actually still has the firewall but unblocks local website and API.
yzorg 2
Its quite Important Infos about an Firmware update. When its making one unable to downgrade afterwards. This is quite very Apple style.. I would need a Big Red Warning upon updating next time... i hope i didnt brick my machine now.
- The printing-cloud-way which needs opening my browser is realy not ideal. I like to do everything form cura as it was.
