I just read the documentation of:
"infill before walls" (was already unchecked for me anyways)
"outer before inner walls"
Both options don't seem to do what I want at all. Or am I missing something here?
Pity that Cura doesn't offer what I want. There seem to be many optimizations that could be done JUST for the first layer that would help immensely.
gr5 2,330
uncheck "infill before walls".
check "outer before inner walls".
This is not enough if you have multiple islands touching the build plate (like the 4 legs of a table would be 4 islands on the bottom layer).
HOWEVER, 90% chance that your issue is because your nozzle is too far from the bed. When first layer doesn't stick well there are many issues but most common is the bed is too far. To prove that if it starts to not-stick push up on the bed a little (or down on the nozzle gantry) and see if it's suddenly doing better.
shoe 1
Thanks! I will check it out.
So even with this setting it will print separate objects on the print plate fully and not just the wall of every object? If I import cube.stl and then ring.stl, using your settings, it will print all the walls of both stls first or will it finish one object after the other?
No doubt the nozzle distance is the main problem. Still, sometimes it is also definitely some microscopic "dirt/grease" from my fingers pulling of prints or dust. When I quickly clean with Isopropanol or put my glass bed in the dish washer, it always prints perfectly.
Doesn't mean the Nozzle distance isn't the main culprit. Just means, despite the suboptimal nozzle distance it managed to print well since it was super clean.
Nozzle distance always is a compromise for me. Either some parts of the print bed are too close or some are too far away. I can use my full print surface with my compromise adjustment but I need to keep it super clean, otherwise a few areas don't stick well. It is always the first layer and 99% some corner. But just the tip of the corner. The flanking sides are rock solid stuck to the bed. Maybe I should look into printing corners (FOR THE FIRST LAYER) super slow. Does such an option exist?
What I still don't fully understand is why some parts (usually corners) lift up but other very close corners don't. It seems random and not necessarily related to how optimal the nozzle distance is at that position. I know the principles why this happens but I think there are still some unknowns we don't understand yet.
