4.7 (and 4.8) start but never appear (display a Window)
philippe44
Posted · 4.7 (and 4.8) start but never appear (display a Window)
Cura 4.7 was working fine on a Win7 x64. Then, suddenly it does not start (display any window) any more. It's here, consumes about 52MB on memory and sits idle for ever, nothing visible. I've tried to update it to 4.8, no change. All I can do is relate that to install MSFT Teams that has probably added some extra VC++ or .Net components. If I move back to an image before that, it works normally, but the failure really seems to be connected the installation of Teams (I've installed a few other apps the same day, so difficult to corner the exact one). It's pretty frustrating as *everything* else works normally. Anybody has heard about something similar?
    I should add that after ~15 mins, Cura appears. Loading an objects takes another 10 minutes. Then I can rotate view till I modify something in which case it goes for another 10 minutes
        • 4 replies
