What does the M0 command represent? My printer is a crs10 pro, I just flashed it with tiny machines version of Marlin's firmware. I'm not sure is the problem originates with my firmware or just my knowledge of Cura. Where can I read about different options?
GregValiant 1,488
It would appear that Tiny Machines is a re-seller of various manufacturers printers and that they upload their own firmware. To make sure, you need to go back to Tiny Machines and find out what the gcode pause command should be, and how to restart.
Layer numbers in a Gcode file are "Base 0" and in Cura they are "Base 1". When you look at a preview in Cura and decide that you want to pause at layer 9 then in the Pause at Height dialog you would enter an 8 (the Cura layer -1).
3 hours ago, setlab said:What does the M0 command represent?
See https://marlinfw.org/docs/gcode/M000-M001.html
It should be just a pause. But it could be that tiny machines somehow tied it to filament detection
ahoeben 2,047
I don't know your tiny machines printer, but you might try using one of the other "Method" options if the M0 command confuses your printer.
