Posted · Ultimaker S5 print via API
Hello,
I am trying to start a print via the RUST-API, but unable to do so because I don't understand what the problem is,
I have written some code, which is attached, and when I try to run the start_print.py, I don't understand how it sends the gcode via this CURL request:
curl -X POST --header 'Content-Type: multipart/form-data' --header 'Accept: application/json' -F jobname=test 'http://192.168.4.12/api/v1/print_job'
Thanks in advance,
Jurgen Kuyper
start_print.zip
