Cura takes 20-40 minutes to load and then another 10-20 minutes for each object change
philippe44
Posted · Cura takes 20-40 minutes to load and then another 10-20 minutes for each object change
I posted about this previously but my title was really not clear (I don't like to multipost but hope it's okay for once). Cura 4.7, that I've been using for a while suddenly would take 20-40 to load and then be unusable. It started after I installed Teams on my computer (I also installed have a few other apps that day, so I can only go back to the daily image as a whole). I've seen some related posts here and there but no solution worked. I tried to install 4.8 but no luck. I assume that some .Net or Visual libraries installed broke something, but I can figure out why. Does it ring a bell? Any hint? It's Win7 x64.
Thank you
