13 minutes ago, fbrc8-erin said:I offer non-warranty repairs at our facility if that's something you need; you can check us out at fbrc8.com.
There is no maintenance kit for the S5, but if I was putting one together, here's what I would include:
* Nozzle seals
* Bowden tubes
* Collets and Clips
* Sliding Block Set
* Short Belts
* Front Fan
The parts are all available and that list should pretty much cover wear and tear items, though if you've only run through five rolls of filament I wouldn't expect most of those to need replacing yet. What sort of issues are you seeing?
Not seeing any issues the printer is not here yet but this is a used machine which I would normally not buy but the price was too good to pass up with 190m and 230M of filament usage and saving over a grand off the new price plus it was sold with filament and extra Hot ends.
I should have enough capicorn XS to replace the tubes the rest I'll order if/when needed
fbrc8-erin 316
* Nozzle seals
* Bowden tubes
* Collets and Clips
* Sliding Block Set
* Short Belts
* Front Fan
