Hi @Torgeir,
that's a very promising lead! There actually was some PLA residue inside (mostly threads); I removed what I saw but didn't really think about it too much, so there might be enough left to block it. Do you have some hints how to clean that fan best?
Thanks
Stefan
Torgeir 146
Hi @StefanF,
since this happen after some time printing, I'll think this is maybe due to a faulty/partly blocked front fan (hot end cooling fan). As lack of this fan gradually increase the temperature at the "cold" upper part of the heat block and make filament become soft here before entering the heater (so it will create a lot of additional load for the feeder)..
Check this fan..
Thanks
Torgeir
