I have the material station. I printed this within 1 hour of unpacking the pro bundle. The pva was brand new in sealed bag, until I used it.
The pva seems to be breaking down as it got higher.
I noticed that on the last layer the head was hitting the top layer, and was pushing the job down. I took video.
gr5 2,333
Well I don't have much to go on with this picture but you should know that PVA absorbs water in just a few days being left out in the air so you need to keep it in a sealed bag with fresh desiccant. You can restore PVA by heating it but this might not be your issue. If it gets wet it tends to sizzle and pop as you print it (the water is boiling).
Can you show some screen shots from cura in prepare and also preview mode? And explain what happened? Did the printer stop suddenly? Was there a message? Did you stop it? Did it finish normally? Is that outer material PVA?
