Handling overhangs is part of a steep learning curve and often result of trial and error. I'm still surprised of the ability of my printer to handle overhangs I just regarded as impossible.
For round arcs and overhangs angled less than 45° you definitively don't need supports. Many objects are designed to avoid need of support in just this way.
In Cura preview, you should be able to see the generated support. But of course the color sceme for "helpers" and the related extruder must be activated.
1
Enigma_M4 125
if you attempt to avoid using supports, the upright position ist the best, because the arcs don't need any support. But regard that your adhesion surfache on the print bed is VERY small, so you need at least a good brim.
If you've a dual extrusion printer and can use dedicaded support material, such as PVA or Breakaway, you shouldn't look for avoiding support but best position of print object, especially needed strength (layer adhesion is the most weak point of a printed object).
Regards
DadOfThree 0
Thank you. I'm not necessarily looking to avoid using supports. I guess my inexperience is getting the best of me and not understanding how a 3d Printer will handle those gap / arcs. After slicing with supports enabled and having the part on its side, I didn't see any difference in the preview. I was expecting to see something in the middle, where that gap is.
