Hmmm well I don't need ssh per se but I was hoping to be able to e.g get some data on the print status, send gcode directly and possibly via a nodejs server. If that's not feasible then OctoPrint becomes a lot more tempting but then the "Connect" aspect seems rather limited.
Is there then a DigitalFactory or any API to programmatically send and execute some gcode??
Edited by utopiahAPI
Smithy 754
There is no developer mode on the UM2C, the SSH daemon is not running.
On the other hand there is not much for tinkering on this printer. The SSH daemon was running in an early beta version so I was able to take a look into the system, but there is mainly just the display gui thing and the daemon which connects to the digital factory. Also the Onion board itself has not much space and memory to run too much things, maybe that's the reason the SSH daemon was stopped by UM to save some space for other things.
In theory you could try to connect a console cable directly to the Onion board, but in my opinion it is not worth the effort and not worth to loose the warranty on a new printer.
