ok thx for awnser. Well my biggest problem are when using lwpla. would maby have been nice
if that was a options butt i dunno maby already been tested and dissmisted. O well ill try tweek whit
retracs and if i found out something like coasting distance
GregValiant 159
No. Retractions are on their own line in the gcode file. You can adjust the amount of retraction and the speed of retraction, but as you have found out the head doesn't move during a retraction.
Oozing (or Stringing) is often a function of printing temperature and retraction distance rather than of retraction speed. Bowden tube printers have much "give" in the bowden system and can handle retractions of 6.5 or more. When retractions get too long they pull molten plastic up into the bowden tube. That creates it's own problems. Fast, long retractions are the normal fix for stringing.
White filament has a lot of colorant in it. I print white PLA at 200 and almost every other PLA at 210.
