Ok, sure.
GregValiant 1,489
The initial purge line is hard-coded in the Start Gcode. The rest of the file is calculated by Cura.
0.1 initial layer height...I would make it equal to or just more than the regular layer height. With such a thin first layer there might not be enough room for the filament to escape from the nozzle if you miss the leveling by only a little bit.
Under Mesh Fixes change the Maximum resolution and Maximum travel resolution to 0.5.
Under Experimental you have Use Adaptive Layers enabled. Turn that off for the Benchy. It's a special use thing.
All I see in the Cura settings and the printer settings is that low initial layer height. Sometimes Volumetric extrusion can get inadvertently turned on. In the printer - make sure "Main | Control | Filament | E in mm3" is turned off.
GregValiant 1,489
If you could post a problem Gcode file and use "File | Save Project" and post the 3mf project file they might shed some light on the subject.
