Posted · Cannot slice Blender STL
I bet it's there - but the floor space of your house is only 1x1.5 (mm) - the height is 2.3mm (chimney included) - it seems to be some kind of a tiny house... 🙂
The size is shown in the lower left corner of your screenshot, but it is not readable (i guess the forum software scales large pictures down).
It should be possible to select the object with CTRL+A - afterwards you can use the scale tool. A scale factor of 2000 or 4000 percent gives it a printable size. 1
While we are at it: there are some overlapping vertices and the normals of some faces are pointing inwards.
I changed the units to mm and scaled it a bit:
simple_house.blend.zip
