GregValiant 157
With that many parts on the build plate the chances of one failing and taking the others with it are pretty good. A clogged nozzle 30 hrs into the print could be a disaster.
It was my bad. I see it is 2+ days to print. But 53 hours running continuously is tough on the machinery.
My advice is to split this up into 3 or 4 models at a time. I know you have a big build plate but it isn't necessary to fill it.
If you can't alter the Platter.stl file then use support blockers and set them to keep a bunch of pieces from printing. The image below is 1 big support blocker set as a cutting mesh. You can add more and scale them and move them like you would any other model. Even with that support blocker the print is 22 hours. If it was me I would block out a couple more for the first print and then uncover some and block others for the second and third prints.
Edited by GregValiant
GregValiant 157
I can open the file in Notepad++ but Cura tells me the file may be corrupt and it won't open it.
At 161mb and 5,480,369 lines that's the largest Gcode file I've seen, and at 4+ days to print it's also the longest.
The first move in the file is G28 to home the print head. After homing it stays in the area of the left front corner to print the skirt around a part. All the early gcode is consistent in that area. There are no moves above X100 until line 9434 in the gcode. The MaxX in the file is 297.036.
The problem is either that the file size is making your printer sick, a bad memory card, or a glitch in your firmware. The printer is making a move that is not in the gcode. That's never a good thing.
The image shows the gcode file read into AutoCad. There are no movements off the build surface of 300 x 300. This is through Z 24.75. FYI The magenta lines are travel moves.
Zeesa 0
I had no idea! In Cura It told me it would only take 2 days to print too, so thats strange... I could try modifying the original stl again and see if that works? But if the file itself is just messed up, is there anything I can do about it? this is the original file
Platter.stl
